A little simple tip for elements that don’t have beveled corners, give them a tiny corner radius in KeyShot (select item, than at the bottom at properties).
That way you get reflections on edges so it adds a lot to realism. For example that plastic power plug has some infinite sharp edges which don’t exist in real life, giving them a very tiny radius in KeyShot helps a lot making it more realistic.
And it’s great you can do it without actually beveling the edges in a 3D program since it always makes changes harder.
Thanks for the tip. Will try it
it’s rich & fabulous
